How good of a deal is this for odyssey batterys
Snag em before someone else does.
Will do. I'm currently running 2300wrms to my sub and 400wrms to vocals the lowest I ever seen my voltage go was 11.8 sitting at a light full tilt, and I don't do a whole lot of parking lot pumping so would there be much point in putting in more then 2 as a starting and secondary battery? Thanks
Go ahead and use the two you want and see how it goes, and if everything is fine you can always sell the other two and make your money back.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Definitely snag them, they are roughly equivalent to an XS D3400 spec wise.
He was using them for a UPS system, which means uninterrupted power supply.
Compare the dimensions to the existing Group class battery that is in there. The dimensions look comparable to a D3400, it's actually slightly smaller so you should be good. I don't know which group battery you have now, as far as which side positive and negatives are located
  • Who's Online   0 Members, 0 Anonymous, 8842 Guests (See full list)
