Pasta Prime Posted February 10, 2016 Report Posted February 10, 2016 Im in the planning stage of a new build and it will consist of, when complete, two 3500/3800 or something close to that on two 18's most likely zv4's wired down to 1.7 - .7 ohm. Plus a four channel. What kind of battery bank am I going to need? Not lithium as much as I would like to. I want to plan for the future in this build even if it takes a while to acquire everything New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
Skullz Posted February 10, 2016 Report Posted February 10, 2016 You'll want at least 800 amps of alt and battery bank, but i would at least have as much as you need in a battery bank and have as many alts to charge them with so you have as little voltage drop as possible. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Pasta Prime Posted February 10, 2016 Author Report Posted February 10, 2016 I definitely want to over kill the electrical but i'm not sure I can get the alts i need. I guess I should have said but it's going in a civic hatch. I was looking though and it appears I could run a second alt where the ac pump is possibly. I haven't even looked into what alts out there for the civic yet. You know of any builds that are similar? I have found a couple but not much info out there as they are older builds. New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
