2002 chevy avalanche dome light wiring
does anyone know which cable goes into the dome light?
i belive orange is constant
white is switched
and black ground
I had it disconnected for a while when the bass broke it
So if anyone know whick color goes into the inputs please help
heres a pic of the wires
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
If that is to hard to read if u have a test light put the ground on the black wire , close all doors put test light lead on one other wires with door open witch ever wire lights up is the door switch wire then do same thing with door closed and turn on your dome lamp switch on the dash witch ever light lights up is your dome switch pretty easy.
The input is into the dome light
i broke the connecter so i soldered the cables on the terminal
inputs but when i connected them a cerain way only the ones you
push to turn on turned on
then i did it a difrent way where the dome light turns on but when rverything is off doors open then they turn off
but imma try to what you said n see how it goes
thanks
Ok i know which color is which
But now my problem is where in the dome light input i out the canles
exp:??
I have 3 cables n 3 inputs on the dome
where does the location to each cable to make it work properly without burning out any fuses which i did today
idk how no cables touched but happem to me before so i just have to change the fuses that burned out upfront or driver side fuses.
