Clayton Hartweg Posted February 14, 2016 Report Posted February 14, 2016 so i got a BL Series BL15. The amp is a SoundQubed Q1-2200D. well the problem is the car the car is a 06 dodge charger . note this is the box i have in there now for my 2 12s that i am tanking out http://www.stevemeadedesigns.com/board/topic/200168-help-on-box/#entry3020443 all the way at the bottom thanks!
Joe X Posted February 15, 2016 Report Posted February 15, 2016 So here is a suggestion based on the dims provided in the other thread, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
