Awaiting_Equinox Posted February 19, 2016 Report Posted February 19, 2016 those hds3s like a big box, build a custom box do 5 .5 cubes net tuned at 32 and you'll be good bass and bewbs.. and beer
Brad Majors Posted February 19, 2016 Author Report Posted February 19, 2016 anyone able to draw me up a box? up to 40 wide and 16 tall. would like sub up port back.
Joe X Posted February 19, 2016 Report Posted February 19, 2016 So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 5 3/4", figure is just an assembly guide:
Brad Majors Posted February 19, 2016 Author Report Posted February 19, 2016 wow thanks man this is perfect.
Brad Majors Posted February 19, 2016 Author Report Posted February 19, 2016 was this ins sketchup if so can you send me the file? would be amazing if not thank you for what uve done so far also just wanting to clarify the extension off the main port length is that right at only 1 5/16 length? thanks wait what is the extension? on the pic above can you tell me what the x 2 extensions are? thanks
ckeeler11 Posted February 19, 2016 Report Posted February 19, 2016 wait what is the extension? on the pic above can you tell me what the x 2 extensions are? thanks The triangle against the back wall in he port.
Brad Majors Posted February 19, 2016 Author Report Posted February 19, 2016 wait what is the extension? on the pic above can you tell me what the x 2 extensions are? thanks The triangle against the back wall in he port. ah okay thank you
Awaiting_Equinox Posted February 21, 2016 Report Posted February 21, 2016 that sounds like well over 5 cubes net.. download torres and play with the numbers. bass and bewbs.. and beer
Awaiting_Equinox Posted February 21, 2016 Report Posted February 21, 2016 oh shit, Joe x helped you out I see. he helped me on mine for my 4 15s cvrs and it came out good. hit a 146.3 sealed on music, with voltage drop to the high 10s and 11s, so it could have been way louder. that same box now holds my 2 18s which sound louder than the previous setup. my advice is take his blueprint and get building.. you wont be disappointed bass and bewbs.. and beer
Brad Majors Posted February 21, 2016 Author Report Posted February 21, 2016 yep yep waiting for the subs and amp and wiring all to come in then ima get the box built in the mean time. will post once its done thanks guys
