erwindmac Posted February 19, 2016 Report Share Posted February 19, 2016 I am trying to build me a ported enclosure for my jl audio 10w6v3 sub which will be powered off a jl audio 500/2 but i am not sure if i should build the box jl audio recommend which is a .75 cubic foot enclosure tune at 39hz or maybe something bigger but with a smaller tune. The type of music i listen to is rap and hip hop and sometimes rock. Now i am not looking to be heard miles away or anything like that I am looking for more of a sql setup. 21.5" x 12" x 11" w x d x h Link to comment Share on other sites More sharing options...
Joe X Posted February 19, 2016 Report Share Posted February 19, 2016 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 1 1/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted February 20, 2016 Report Share Posted February 20, 2016 What type of vehicle are you putting this in? This will have a big impact on the design you need. Owner of BigAss Ports Link to comment Share on other sites More sharing options...
