RyanRosier Posted March 2, 2016 Report Posted March 2, 2016 So what's the input on this headunit? Worth anything in a decent sized build? It junk.. Or what? 2003 Chevy Silverado Reg Cab. Rockford Fosgate 500a2 and Kicker ZR240 each on their own 12" Kicker Comp S. Small, but everyone's gotta start somewhere.
BoomZoom808 Posted March 2, 2016 Report Posted March 2, 2016 So what's the input on this headunit? Worth anything in a decent sized build? It junk.. Or what? It's ok I would step up to the 9600 if I was you or the prs80 if you need to go active The 9600 is a much nicer unit 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
RyanRosier Posted March 2, 2016 Author Report Posted March 2, 2016 So what's the input on this headunit? Worth anything in a decent sized build? It junk.. Or what? It's ok I would step up to the 9600 if I was you or the prs80 if you need to go active The 9600 is a much nicer unit And that was exactly what I was looking for, Im hearing all this stuff about active and active xovers, so car to explain what all that means..? 2003 Chevy Silverado Reg Cab. Rockford Fosgate 500a2 and Kicker ZR240 each on their own 12" Kicker Comp S. Small, but everyone's gotta start somewhere.
BoomZoom808 Posted March 2, 2016 Report Posted March 2, 2016 You might just want to stick with the 9600 until you learn a little bit more. Basically going active you can fine tune what frequency bandwidth is sent to different components of your system instead of using the set cut off Low pass, high pass and subwoofer filters. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
RyanRosier Posted March 28, 2016 Author Report Posted March 28, 2016 You might just want to stick with the 9600 until you learn a little bit more. Basically going active you can fine tune what frequency bandwidth is sent to different components of your system instead of using the set cut off Low pass, high pass and subwoofer filters. What double dins are like the prs80? 2003 Chevy Silverado Reg Cab. Rockford Fosgate 500a2 and Kicker ZR240 each on their own 12" Kicker Comp S. Small, but everyone's gotta start somewhere.
