reedal Posted March 8, 2016 Report Posted March 8, 2016 check subwoofer wiring. You could be out of phase. Make sure the sub (low) setting on the head unit isn't turned down or muted SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
reedal Posted March 8, 2016 Report Posted March 8, 2016 Oh, and 12ga will be fine for that power, even if it's CCA and not OFC SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Aztahoe99 Posted March 8, 2016 Author Report Posted March 8, 2016 What do u mean out of phase. I put the ohm meter on the pos and neg it says 1.7 hooked up to the amp it says 2.4 i thought it should be 1
reedal Posted March 8, 2016 Report Posted March 8, 2016 It should say 1ohm if you're wired series parallel. Touch the leads of your multimeter together and read their resistance. That is the number you should take away from each resistance reading to know what the true resistance you are reading. Disconnect all wire from all subs, and measure the resistance of each voice cool individually. Each should read 2ohm, but may vary some. Remember to subtract the amount of resistance caused by your leads. If all voice coils are reading correctly, reconnect all wires series parallel, in accordance with this diagram http://www.the12volt.com/caraudio/woofer_configurationsm.asp?Q=4&I=22 Measure final resistance before connecting to amplifier. Should read ~ 1ohm. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Aztahoe99 Posted March 8, 2016 Author Report Posted March 8, 2016 Well i just disconnected the spraker wires so i woudnt hear the pop and was going to cruise down the street to the sound shop. Syarted the truck put it in drive and gave it gas amp box poured out smoke. .... Im guessing this amp is toast? Not even two hours of unwrapping it
reedal Posted March 8, 2016 Report Posted March 8, 2016 You should have turned off the head unit entirely or removed power from the amp. Some amps don't like being powered on without a load, and apparently yours is one of them. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Aztahoe99 Posted March 8, 2016 Author Report Posted March 8, 2016 Nice not a good day was just pulli.g the subs back out to check wiring and punctured the rubber foam with the tip. Probably won't be to good for it.
Aztahoe99 Posted March 8, 2016 Author Report Posted March 8, 2016 Damn now two with punctured foams . Fml
reedal Posted March 8, 2016 Report Posted March 8, 2016 You can try getting the sub warrantied by SoundQubed, but most times something like that, a company will not warranty a user error. If they will not warranty it, I'm sure there are ways to repair a surround, just do a lot of searching. As for the amp, try and warranty it as well I suppose. Try to take your time when doing things in order to avoid more punctures or other damage. No need to risk spending money unecessarily because you're in a hurry right? The good news is, puncturing the surround doesn't damage the voice coil, so you can still check the resistance and make sure you get it all wired up correctly before contacting manufacturers about repairs, or searching ways to do it yourself. Good luck SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
