Speaker wire a vs speaker wire b
Went down to the audio shop other day to get some thicker guage spraker wire for my subs rather than the door speaker wire i had in th e garage. They were closing so i just picked up a prepacked 25ft pack instead of making the lady go in the back measure and cut.off the spool. They sold me the black and white wire wich is silver looki mg but looks to be thicker than this blue speaker wire wich came in an install kit i didnt know i even ordered. But the blue wire looks copper. Both say 12ga which would u guys use
Whatever's the biggest. Truth be told, neither of them are probably OFC. If you have a digital multimeter, figure out which one has the least amount of resistance and use that.
Don't trust a shop but you personally just smoked two decks, makes sense.
03' Trailblazer LT
Dayton Designer 6.5"s & Silkie tweeters
Dayton Audio Ultimax 18"
Pioneer 9601 & 8604
XS Power D3400
2 runs 1/0
Singer 250
Thx guys the silber looking stuff had 4.8 copper at 5.4 usin the bigger looking wire with least amount of resisramce.
Nother question. Im doing 4 subs 2 ohm dvc wiring series parallel to 1 ohm final load. I have a diagram that shows me how but it has it all connected and just one positi e and one neg going to the amp. My mono amp has dual pos and dual neg. Km assuming inside the amp its all ghe same should i use one connwction for all foir or two for each pair of subs.?
if you use both connections on the amp you will use more wire but said wires will carry less wattage per run than making all the power flow down 1 path of wire.... depending on how long the wire is and what gauge can have a parasitic loss, there are online calcs to figure out such math on current through wires..... depending on what your system has and power demands/output this difference may be negligible.... IE 25watts
Depending on how much power you're pushing, more wire will be better and reduce loss between the amp and subs. How much power are you running to the subs?
Edit: ^^ beat me to it
4 hds212 about 6 to 700 ea,h sub.
So i have everythi NH wired up and cant get these things to work. Amp turns on subs were popping randomly low bumps but noy playing yo the music what gives. Deh80prs deck 4 12s mb quart 3000.1 with ots own 0ga wireing what should i check into
  • Who's Online   0 Members, 0 Anonymous, 2278 Guests (See full list)
