Broke_Audio_Addict Posted March 13, 2016 Report Share Posted March 13, 2016 Boost should be all the way off, lpf at 80hz or lower, ssf will depend on the tuning of your enclosure. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 13, 2016 Report Share Posted March 13, 2016 Well basically the ssf should be set a little lower than the port tuning frequency to keep the sub from unloading and damaging itself. A sealed box doesn't have this issue. The LPF would be set somewhere below 150hz to keep the sound image up front. The boost you shouldn't need but some systems can benefit from a little boost around 45hz. Use the search function to dig all this good stuff up. I have learned tons in my short time here. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted March 13, 2016 Report Share Posted March 13, 2016 I would never cross at 150hz on subs. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted March 13, 2016 Report Share Posted March 13, 2016 Yeah 150hz would be kind of high, it depends on how low the front stage can play. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
Bigwheelw Posted March 14, 2016 Author Report Share Posted March 14, 2016 If anybody has a thought to buy this amp...take it from me. It's not worth it. It is small and compact. If that's what you're looking for then it's good, but if power is what you're looking for then keep looking lol. It might be good for 6x9s Link to comment Share on other sites More sharing options...
