2 sundown E-10 port help
Jamesv
Like it says...got 2 sundown e-10s, in 2.5 cubes with a 3" aero port. It is 5 inches long, which will be right about 32 hertz, and 35in of port. Sundown's site says 16in per sub. Haven't finished install, but finished enclosure, but didn't know if I should go for 2-2" ports about 5" long each instead? Thanks for the help guys! Going for aero ports for efficiency.
You would need 3 3" ports to run those two subs, unfortunately placing them now would reduce your internal volume.
How much power are you putting to these?
You are calculating port area wrong, its a two dimensional measurement, length of port is irrelevant when calculating port area. A 3" port has just over 7" sq in of port area, so you are way, WAY undersized with a single 3" port.
Builds:
So if using 3-3" ports it says I need 20" port length to get to 32 hertz. Is that 20" each, or total? Good thing I asked, I always thought calculating ports was 3D not 2D when trying to match it to the recommended port area.
They would need to be 20" long each.
Builds:
I don't have that kind of room. So slot port it is, with a fiberglass bottom that is contoured, and a 20* degree slant back piece. Should be fun. Thanks for the knowledge and help guys!
  • Who's Online   1 Member, 0 Anonymous, 3315 Guests (See full list)
