I want to know how I can use my radios eq with out using the one on sub amp which has no way to shut off or run to full. I'm trying to avoid phase distortion. Any help is well come.
I think you are combining EQ and Crossover together when they are two different things. Or maybe using EQ in place of Crossover.
If you want to use the Low Pass crossover on your deck its common to just turn your amp low pass crossover setting to the highers frequency- usually all the way clockwise.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Also, the Sonic Electronix vendor page is not the best place for this topic.
Welcome to the forum!
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1443 Guests (See full list)
