Building a box for two HDS 200 10"s
Hugh Janus
Hello, first off i would like to say that I used to have an account on this forum under the name Impalalpine. I cannot log on to that profile anymore, wasn't banned, just lost my login.
Anyways here are the numbers and what I am looking to do: Im looking for any input & advice anyone has.
Car is a 2004 Chevy Impala
Trunk max dimensions are as follows
37" Wide
15" High
23" Deep
The subs are soundqubed HDS-200 10's, two of them.
Amp is a Q1200.1
I listen to hip hop, rap & some rock but like low tuning. The boxes I have put together (using RE box calculator) have been tuned very low (between 25- 30hrz)
thank you for taking the time
2004 Impala:
80 PRS deck
( 2008) Rockford punch 500.4 (mids, highs) x2
Soundqubed Q1200.1
Soundqubed HDS 200 10"s x2
Alpine type S 6.5 x 6x9's
All Knuconcepz wiring
Moving forward with the battery bank.
Two group 27 lead acid Batts to support the q1200.
Stock alt
Ordering two distro blocks from knuconcepz as we speak
2004 Impala:
80 PRS deck
Soundqubed Q1200.1
Subs & amp came in yesterday but the amp got delivered after I left work. Will post pics monday when I get back into town.
Put together a wiring diagram for how the electrical is going to work this time around yesterday before I took off for the weekend.
Still screwing around with RE box calculator but i'm afraid of ending up with some wild tuning. Im going to explore torres box calculator.
2004 Impala:
80 PRS deck
Soundqubed Q1200.1
So here is a suggestion, power: to subs rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Thank you Joe x for taking some time to put that together for me.
I will be sure to post pictures of the final product, also I will start a build thread in a diffrent section and link this one to it.
It looks great
2004 Impala:
80 PRS deck
Soundqubed Q1200.1
  • Who's Online   1 Member, 0 Anonymous, 537 Guests (See full list)
