Sub Stops Playing, AMP ISSUE? Amp Doesn't Protect (still green light)
sovka_17
I used 2 different sets of rcas and triple checked my grounds even rewired it all. Running 3 xs3400r batteries. I will have to do the headphone jack rca test to bypass. I tested at volts at the rcas and got between 0-0.02v. Both cables. Stock head unit.
So with your headunit at max clean volume you're only seeing 0.02v at the rca's? Sounds like the deck has issues. Get a helper and do a sweep, start at volume 0 and have your helper increase the volume slowly as you read the voltage. It should steadily increase. What about the voltage on the front and rear outs?
  • Who's Online   0 Members, 0 Anonymous, 660 Guests (See full list)
