Subs cut off at high volume
Ran a wire from the power wire to the remote wire and it came on.... I just replaced the signal wire tho lol.
That's how almost every amp works, when they see battery(ish) voltage on the remote they turn on. That doesn't really answer what the problem is though. I'd double check your ground.
K I'll try grounding it somewhere else. I've ran it there forever tho and before I put it on there for this amp I cleaned it real good with a wire wheel.
Yeah the amp is fucked I jumped the remote and it started beating and was just beating weird. I'm gonna unhook it :(
Did you check the remote wire going into the amp? Probably fried it so you might have to find another source for turn on....
The source as in my head unit? I had just replaced the remote wire when I first installed the amp cuz it wasn't coming on and that fixed it.
Yea at the head unit, check to see if it gets voltage when the radio turns on...I would check behind the head unit...instead of at the amp...if you get nothing than its fried so you might have to either run it from a switched source at your fuse box...
