BMS Posted March 22, 2016 Author Report Posted March 22, 2016 yes i have looked at the sp4 but i don't love the sensitivity of 86db but a definite possibility.
BMS Posted March 22, 2016 Author Report Posted March 22, 2016 anyone know the specs on the resilient sounds platinum 15? they don't seem to list them .
DubNDodge Posted March 22, 2016 Report Posted March 22, 2016 you do realize what that 86dB means right? The subwoofers abilitiy to play 1000Hz at 1w at 1 meter away. Rather useless rating for subwoofers. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DubNDodge Posted March 22, 2016 Report Posted March 22, 2016 The only specs you should be directly concerned about are the BL, QTS, xmax, Fs. Even then, specs aren't everything. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
BMS Posted March 22, 2016 Author Report Posted March 22, 2016 I like the hdc4 15 also but i can't find a sensitivity rating.
BMS Posted March 22, 2016 Author Report Posted March 22, 2016 i wan't aware it was rated at 1k specs aren't everything i know but what else do you have to go off of? and i cant imagine sensitivity is useless. and those specs the t/s parameters i don't honestly know what they say about the woofers response but i know i need them to calculate enclosure size ect.
DubNDodge Posted March 22, 2016 Report Posted March 22, 2016 you didn't know what the sensitivity meant yet you are so stuck on that spec. sensitivity is more relevant when a speaker is playing in the 1khz area '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
BMS Posted March 22, 2016 Author Report Posted March 22, 2016 well i would like the subwoofer to be efficient and that is all i have to go off of even if it is at 1khz and it doesn't directly relate to efficiency at lower frequencies.
BMS Posted March 22, 2016 Author Report Posted March 22, 2016 how and why would i pick a woofer based on it's t/s parameters.
DubNDodge Posted March 22, 2016 Report Posted March 22, 2016 BL = Motor force. Length of coil in the magnetic field. xmax = point of excursion that there is 70% BL Fs = frequency the speaker itself resonates, sorta shows how low the subwoofer can play. Although box is a large factor too. QTS = what box a sub would prefer (<.4 leans towards ported >.4 leans towards sealed. As a general rule of thumb) As I said before, thiele small parameters are not everything though. edit: more knowledgeable people feel free to jump in and add/correct me '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
