Type R Dual sub enclosure
Yeah I can do a 3D view for you when I get home later today.
Builds:
Looks like this box will only work with a port out of the back.... Subs don't leave enough room for the 3" port. Let you know how it goes
AQ3500.1
15" Fi SP4
1/0 Knuconceptz Power/Ground
1/0 Sky High Big 3 Upgrade
Pioneer AVH-4200NEX
XS Power D1200 Underhood
Intimidator Gel In Trunk
CES 250A Alternator
Here is how I would lay it out:
All panels except the top and bottom are 14" wide.
Builds:
So working off the cut sheet before you posted the 3D rendering caused an issue. After cutting my pieces it became apparent I couldn't fit the subs next to each other... In retrospect that was probably my faul haha. Either way. I ended up still porting it to the some tune I just have the port firing from the side. It' sounds good so far. Going to ouch it much more tomorrow and see what I can get out of it.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Your efforts are appreciated and won't go to wast if I'm unhappy with this setup I'm going to pull it and build this one, I like the forward Facing port much more. I'll post some video tomorrow when I can put some real juice to it. How long should I wait to full tilt these things?
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
34036850-A5C9-4CF8-AAA0-3E6351D32899_zps
FB251734-38FC-4A33-A429-D0D7E7F0C333_zps
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
65BB64DB-9218-40C9-930D-534F0CC5FE77_zps
3AAC7DCF-49B0-4C52-B69E-C59B885FC3BD_zps
Still have room to get my work supplies in the back. Now I just need to dynamat my rear deck. Shits obnoxious.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
Looks good! How does it sound?
Builds:
I think it's sounds great. I was expecting it to be a little louder but I am under powering them a little bit. Plus I have pushed them very hard yet, wanted to give the glue some time to set. Do you think it would be safe to mount my amp to the box on the side where the port is? It's the smallest cut on the entire box. Not really anywhere else i could put it. Also, was I right with my thoughts that as long as the port LxW was the same I would achieve the same port are? Prob a stupid question but my idea was not to butcher your design.
I'll post a video in a bit when I get it back in the care, as you can see I needed to flip the subs.
AQ3500.1
15" Fi SP4
Pioneer AVH-4200NEX
CES 250A Alternator
  • Who's Online   0 Members, 0 Anonymous, 547 Guests (See full list)
