Wiring DVC sub in series question
cbelott
This is a pretty noov question, but just want to make sure I do this correctly. I know in series I run a bridge wire from positive 1 to negative 2. Then run negative 1 and positive 2 to amp. My question is about the bridge wire. Do I use positive or negative speaker wire or do I twist them together for it?
That would be correct. I would make a jumper by twisting the positive and negative together to make one big wire.
Pioneer 80PRS
I just use the same size speaker wire as my neg and pos run. Neg or pos wire is the exact same wire. No need to twist them together to make one bigger wire.
Sure peel the wire apart and now you have one for each sub.
Pioneer 80PRS
depending on number of subs and amp being used I always run the 2 coils directly to the amp on a single sub DVC setup this way all the power does not run through a single speaker wire.... I also only use 12awg cable if you use 8awg then it really does not matter... when mono block amps have speaker blocks that are already broken down into 2+ and 2- why not take advantage of it and divide the power accordingly
  • Who's Online   0 Members, 0 Anonymous, 3078 Guests (See full list)
