Does subwoofer qty affect port size?
buff_n3rd
Hoping I ask this hypothetical question correctly.
If i had a 12" sub that required 1 cubic foot of air and a 4" x 4" square port that is 12" long tuned to 35hz and decided I wanted a second 12" sub (exact same sub) and doubled the volume of the box to 2 cubic feet, does the port need to also double or does it stay constant as long as volume is correct for the woofer?
Seems like some online calculators ask for speaker qty and others don't.
The port would have to increase in size as well.
Good to know and that is what I'm most worried about on my current build.
How much port area or port length would I need for 4 x sundown x6.5?
My port size is 5 x 3.5 and worried I calculated length wrong (that's what she said).
I completely realized after the fact that the question can't be answered without box volume. Right now my net volume is 1.28 cubic feet.
length is also dependent on tune are you still going for 35hz
and did you mean gross volume because you cant have a net volume without the port figured in...
5 x 3.5 x 26.5" long for a 35hz tune and the gross volume would have to be 1.76 not figuring in sub displacement to achieve the 1.28 net volume
if you already have a box that is 1.28cuft then that port will never be able to get you to 35hz because as the port gets longer so does the port displacement changing the tune and then again impacting the volume so you will never be able to drop the tune lower than 44hz-ish
always build a box around the port never build a box and port it later
I meant net only because I was building backwards in my head.
Current box is scheduled to be 1.78 cf minus displacement of subs which is .2 for 1.58 cf. Minus the external port dimensions which is .3 for a net of 1.28.
then this math would be spot on "5 x 3.5 x 26.5" long for a 35hz tune and the gross volume would have to be 1.76 not figuring in sub displacement to achieve the 1.28 net volume"
and you said external port? if you really meant external then you don't subtract this from the displacement but if you meant internal port then the math I listed is spot on to what you mentioned in the last post
It's internal but I was treating the port volume outside of the necessary volume otherwise every change to the port volume would change the internal volume and it would be a back and forth until they match up correctly.
  • Who's Online   0 Members, 0 Anonymous, 6362 Guests (See full list)
