SnowDrifter Posted April 25, 2016 Report Posted April 25, 2016 That greenish bolt? Don't touch that it sets your alignment and is extremely sensitive to adjustment. It's thick metal but not really connected to the rest of the car well, electrically. It's a suspension component ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Rich Schenk Posted April 25, 2016 Report Posted April 25, 2016 for alternator using the mounting bolt. just take one out and get a longer one so you can put your grounding lug to the the alternator case. i personally ground my alt directly to the battery. if your car doesn't have a frame and is a uni-body ground to the top of the shock tower usually a good solid ground that's how i did in my Hyundai tiburon. just make sure you take a wire wheel to it and use dielectric grease for your connections. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
