Atm have a black ice 2600.1 running a 12" l7. It does its job. Going to strap it with another one. It only takes 4 guage, so I only did 4 guage upgrade on big 3. When adding another amp and probably a battery in trunk also. Should I run o guage to the battery in back to a distribution block, and run 4 guage from there? Or will I be fine with the 4 guage? I will reugrade big 3 if i need 2. Stock alternator is 120 amp so im ok there. Its a 2008 saturn astra hatchback. I used to be really into car audio years back. So much has changed.. I bought the L7 cause back then that was beast and I had 1 10 hit 138 in a probe. Im finding out well there meh....
When adding another battery, I would re do the big 3 with 1/0 and also run 1/0 to the battery. Make sure you put a fuse at each battery. In the event of an accident, the batteries will need to disconnect from the 1/0 if it gets pinched. I would not bother with the capacitor and just do the battery.
Pioneer 80PRS
Xs power, north star, kinetic, Shuriken
Do big 4 in 1/0 ofc
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
