XS Power
Battery Recomendations for 07 Hyundai Elantra, 1600 watts
I will be running 2 Pioneer Champion Series Pro subs, both 600 watts, and 400 watts to my mids and highs for a total of 1600 watts. I have big three done under the hood, with a 120 amp alt. Going to be replacing battery under the hood because of voltage drop when bass hits and needed help on which battery to get.
Just a 18 yr old kid looking to learn more about car audio. :)
How much does your voltage drop? what does it drop down to? If you use amps that ACTUALLY put out that kind of wattage I would be curious to see what voltage you drop down to. If you use amps that don't actually put out the wattage you think they do then you may not need much else for electrical. Some people say that at 1000+ watts to upgrade alt but I think that is a little overkill personally. Takes power to make power but C'mon...
If you already did the big 3, are adding a nice aftermarket battery underhood, run some decent wire from front to back (I would suggest one run of 1/0 OFC) and are using a 120 amp alt, if it was me I would see what your voltage drop is like after said and done, if it ends up dropping more than you like, add a small quality, aftermarket battery in back by the amps and for 1600 watts should do the trick IMO.
Is alt PCM controlled and hot charge in the 13's?! Factory alt I'm assuming? What amps are you running?
In the future, just as an FYI when you are saying how many watts you are running you should list your amps more so than the speakers wattage ratings. Also, go by the continuous (RMS) rating and not max power rating. Just because your speakers say 400 watts doesn't mean you will give them that. Some people might have subs that are rated for 3000 watts RMS but are only feeding them 2000 watts. Some people might have a lower grade name amplifier that says 2000 watts but realistically will only ever put out 1200 watts......
EDIT: other people will have other opinions. Hopefully more chime in, we both could learn something. Also, my advice is to stick around this forum for some time and learn some priceless info on car audio to set you straight. this is a GREAT place. I see your signature says you want to learn more. Please do some reading on here before you start your build or you may regret it...
Edited by Karkov
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
There will be two monoblock Hifonics Brutus BRX 1116.1D amps both running at 600 watts RMS and a Pioneer GM-8604 4 channel amp running at 400 watts RMS. The alt is factory and I don't know more about it sorry But I will get the voltage drop numbers asap.
Edited by AJFrrranklin
Thank you Chris for the help on battery sizing. I really appreciate it. Although I'm not sure this is the solution I need anymore :/. I tried testing voltage drop and it stayed steady when bass hit. The whole reason I thought I needed a new battery was because when the HU is at 3/4s volume and the bass hits the mids and highs amp flashes protect mode. I also noticed my interior LEDs dimmed slightly when bass hits at high volume. Is the battery the problem or could it be wiring to the amp? I tested the voltage at the mids/highs amp and at the battery under the hood and both stayed steady when bass hit. I can't figure it out :/
  • Who's Online   1 Member, 0 Anonymous, 1504 Guests (See full list)
