Want to change it up
d-nice88
I was mostly referring to if your amp would be happy with a .66 ohm final load.
Assuming it is, adding a third sub would get you another 1.5 dB of output, in theory. That's not much of a upgrade. You could put more power to three subs though, so there is potential for more gain.
Builds:
I was just trying to get louder then my fi bl 15'subs that I got in a box that is not very well suited for them since the cubic ft is a Lil over 6
Unless you significantly increase cone area/box size or significantly increase input power you probably aren't going to get much louder. That's not to say you won't be able to get a little louder, but don't expect a ton of difference.
Builds:
So I should just get maybe some platform 2 psi 12's and make a good box for them and they would be louder then the sa''s since the high power ones are 1800 rms a piece. Would that suffice the more power and make a bigger box for them? The audio legion 3500 has shown it can put out way more then rated. And I have plenty of batt power and h/of power for it as well.
  • Who's Online   0 Members, 0 Anonymous, 596 Guests (See full list)
