d-nice88 Posted April 20, 2016 Report Posted April 20, 2016 OK so I've had my fi bl subs in my Buick for a good while and I Wana move them to my truck and get 3 12's. Will 3 12's work in a Lil over 6 cubes? Thinking maybe the hds3 soundqueds
reedal Posted April 20, 2016 Report Posted April 20, 2016 Not those 12's. You'll need 7-8 cubes net for three of the HDS312's on rated power. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
d-nice88 Posted April 20, 2016 Author Report Posted April 20, 2016 So best bet would be to get 2 12's 1500 rms a piece. I don't think I have enough space for my 15's so that's why I'm taking them out. Would the hdc.3 12's fit ?
reedal Posted April 20, 2016 Report Posted April 20, 2016 According to AMI Customs (the SoundQubed guru ) yes, those will be fine. His recommendation is HDC312 - 2.5 cube net with 17 sq inch port area per cube - tune between 34-39 hz http://www.stevemeadedesigns.com/board/topic/187809-hdc3-hdc4-optimum-enclosure-size/ SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
d-nice88 Posted April 20, 2016 Author Report Posted April 20, 2016 So many options to choose from. The Sq hds3 fi bl 12 psi platform 2 DC lvl 4 ssa xcon aa 3.0 v 3 ugh don't know which to choose :/
d-nice88 Posted April 20, 2016 Author Report Posted April 20, 2016 What about 3 sa 12 subs up and port forward ? Running an audio legion 3500
reedal Posted April 20, 2016 Report Posted April 20, 2016 You could do that. They don't require as much air space as SoundQubed SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
d-nice88 Posted April 21, 2016 Author Report Posted April 21, 2016 3 sa 12's (the latest model) would be louder then any of the 2 12's I mentioned above since it's more cone area and same power right ? Did I get that right..?
Triticum Agricolam Posted April 21, 2016 Report Posted April 21, 2016 3 sa 12's (the latest model) would be louder then any of the 2 12's I mentioned above since it's more cone area and same power right ? Did I get that right..? Yes, but the difference won't be very significant. Especially if you can't wire to .66 ohms. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
