neonhomer Posted April 24, 2016 Report Share Posted April 24, 2016 A bit of help requested... I checked my max head unit setting for clipping (48 @ 40Hz -0db, 50 @ 1kHz -0db). Then I proceed to set my amp gains. I didn't know which to use, -5db, -10db, or -15, so I used -10. Set both amps to just below clipping. Then I started to run some test tones through to check a few things... WOAH! Clip city! Flat tops from hell! I reset my gains using these tones (40Hz and 1kHz), and left it there. Anyone have any idea if that is right, or if I am doing something majorly wrong? For the record, I am using the DD-1 and CC-1 test disks w/ a Rigol Oscilloscope. The head unit is a Sony Bluetooth unit (test tones in WAV format from D'Amore's website). Amps are Tezla Audio, 120.4D and 1500.1D. Maybe I am just having understanding the usage of the different tones. Link to comment Share on other sites More sharing options...
Jessica Posted April 24, 2016 Report Share Posted April 24, 2016 i like to set mids with -5. but if your test tones after setting gains are 0db and you set with -10db thats your problem. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
reedal Posted April 24, 2016 Report Share Posted April 24, 2016 ^^ if you play test tones with less atennuation than -10dB (-0, -5, -7.5, etc.) you're going to have a bad day. You have to use -10dB or lower tones. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
neonhomer Posted April 25, 2016 Author Report Share Posted April 25, 2016 I guess where I am having the problem is if I am running music, wouldn't that distort like the tones? I'm not sure what attenuation the tones I used are. So... I think I will reset the mids amp with -5db... what about the sub amp? -5 as well? Or just set it all with 0db.... This is where confusion sets in.... I'm trying to keep from frying the sub or door speakers. Before retuning, if I noticed my voltage drop below 12v, I would dial back the sub a little. Then again, I think I might have other problems... not enough alternator (140A), not enough battery (starting battery & Optima Yellow Top)..... Link to comment Share on other sites More sharing options...
