nocturnalrites101 Posted May 1, 2016 Author Report Posted May 1, 2016 i thinkt he effective solution is make the box longer and shorter to pull the port away from the back wall. which is what i was thinking from the start i just needed a number figure of how far it needed to be away from the wall was all.
ShadeTreeMechanic Posted May 1, 2016 Report Posted May 1, 2016 Or just redesign the whole box so you don't have to change the port? That would be my last choice but what ever works. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
