testing amp wattage
Xdq_21X
I'm trying to find out the wattage my amp is putting out. So I'm trying to figure this out cause I can barely turn my gain up any or else it'll start clipping (I have a DC 2.OK and it has a clipping light). so I want to know how much I'm putting out before I drop an extra battery in so I can compare it. I hooked up my multimeter to the positive and negative of the speaker outputs on my amp and I got 33.5volts. I then cut the positive speaker wire and hooked them up to the multimeter (cause I don't have a clamp meter) and I got 5.85amps...so 33.5 x 5.85 = 195....so my amp is pushing 195watts? that's doesn't seem right, any suggestions?
What head unit do you have?
Pioneer 80PRS
Were the speakers hooked up during the test? If yes then you would have to know the ohm load of the speaker at that frequency.
From everything I've read, using just a dmm is pretty hard for benching an amp. A clamp is the easiest way to go.
Your problem is your stock head unit.
Pioneer 80PRS
If the head unit is clipping, then your amp wont have a clean signal. like the old saying goes "garbage in, garbage out".
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 896 Guests (See full list)
