acura_tech481 Posted May 19, 2016 Report Posted May 19, 2016 Hey guys, I'm looking for an enclosure design for a single 12" Sundown Audio NSv3 12" subwoofer. Any help would be greatly appreciated! I see 'Joe X' being pretty active in this department so maybe he'll chime in! Preferred design - Subwoofer up, port back (slot port) Material thickness - 3/4" MDF Preferred external width - 21" Preferred external depth - 28" or less (leaves me with 5" of space between the sub and tailgate or more space if less than 28") External height - doesn't matter Preferred tuning - 30hz or make a suggestion?
Triticum Agricolam Posted May 19, 2016 Report Posted May 19, 2016 How much power are you running and what vehicle is this going in? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
acura_tech481 Posted May 19, 2016 Author Report Posted May 19, 2016 Vehicle is a 2006 Acura MDX - reason I want the enclosure in the dimensions I specified is because eventually I'll be getting a second one and I want them in separate enclosures so it's easier to remove myself since I actually use my cargo space at times. Thanks for your reply! I'll be running a Rockford Fosgate T2500-1bdcp I should also add the I plan on buying the dual 1 ohm voice coil model and running it at 2 ohm's.
Joe X Posted May 19, 2016 Report Posted May 19, 2016 Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
acura_tech481 Posted May 19, 2016 Author Report Posted May 19, 2016 Thank you very much Joe! What diameter are the rounded dowel supports? Don't want to throw off the box volume.
