physics of a sub and moving air
does someone know the physics behind a subwoofer? as in how is it that they move air to be able to do hair tricks? i understand big woofers move air thus = hairtrick but does anyone know the science behind it all?
i have 3 tens sealed in a single cab. theres no port there fore no air escapes from the sub box. but yet i still move enough air to significantly move paper in my window. how does that work. what science is at play
It's the same as how wind blows things around. The air around us is a mixture of gases, including but not limited to: nitrogen, oxygen, argon, and carbon dioxide. The atoms of these intermixed gases are bumping into each other all the time, and when the woofer drives forward it displaces the surrounding atoms. Those atoms move and slam into other atoms, which slam into other atoms, and so on.
Eventually those chain reactions of bouncing atoms run into hairs, or plastic bags, or shirts or whatever. If you have a large amount of cone area (Sd), and a large amount of movement (xmax), you can push a lot of atoms around.
I like this. do you know what kind of energy this is? also how does cone size relate to that? my 3 tens vs 1 18?
Not positive but iirc sub physics are basically piston physics. Kind of like turning your car into a big compressor except with no intake so it doesn't build pressure constantly, it just increases and decreases it rapidly.
I'm pretty sure it's kinetic energy.
  • Who's Online   0 Members, 0 Anonymous, 2460 Guests (See full list)
