Sub box for 15" Fi SSD
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
If you are taking most of the width and height of the trunk consider a firing forward/sealed off setup.
Here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/4", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Thankyou I really appreciate it
  • Who's Online   0 Members, 0 Anonymous, 2366 Guests (See full list)
