gain matching amps? a few questions
Masterbasser
Ok so as far as gain matching amps this is how i udnerstand about doing it
I play a test tone on the deck and set the gains with a dmm on the speaker outputs and match the voltage reading.
now heres my question.
Can i set them at a low volume and gain match them? where i live i cant be doin loud ass burps or anything
Do i need the subwoofers hooked to the amp to gain matc the amps?
Right now i have the 2 amps set under clipping using track 3 on smd dd-1, surely this is not gain matched though considering they are same brand amps but 1 is a newer version with slightly different internals then the other 1
Kenwood excelon ddx795
 3 370 amp CES alternators (audio side only)
       McLaren dome tweeters                                   Crescendo 6.5 ultra neos
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
                     4 Digital Designs m5's at .7 ohms each
        2 K2 80 ah lithiums
                              3 group 31 agms                                       Ledglow million color (12 piece)
2007 Yukon xl
The gain match would be done with the subs unhooked with a DMM and a 60hz tone. Set them up with the DD1 and then match them by turning the high one down to match the low one.
Pioneer 80PRS
exactly what I had planned just wasn't sure if it could be done with subs unhooked. should the gain be matched at full tilt volume setting? or any volume is fine?
I'm guessing whatever volume I play it at the most?
                                                 NVX JAD800.4
                                            4 PA x4 SPL 18's
        2 K2 80 ah lithiums
2007 Yukon xl
you can use the 40hz tone you set your gains with at the volume you set your gains with. Much more simple, no subs hooked up.
does the frequency matter to much as long as its a substage frequency?
  • Who's Online   1 Member, 0 Anonymous, 1331 Guests (See full list)
