Dual 18" 4th order bandpass
Mindzor
Hi there. I'm new to this forum, so i want to say hello to everyone.
So right to the point. My brother just bought two Alphard DB318 woofers.
After some time I came with an idea of 4th order bandpass.
Seald part is 5.5 cu ft and ported part si just above 11 cu ft tuned to 48Hz.
So i just wana see your opinion on box design itself.
Hard to tell from the pic, but the port area might be a bit low.
What amp is going to be used? What kind of usable bandwidth are you hoping for?
Builds:
OK, that amount of port area should be fine.
My suggestion would be to make the port adjustable or removeable so you can change the tuning once you get it playing. You may want to shift your tuning down a bit once you listen to how the box performs.
Builds:
I was thinking to make a bigger opening where the port is so i can mount and reach woofers and then close it with the port so it stays flush from the front. Front panel will be made from double 3/4in mdf so i can make like a slot where my port will fit.
If you understand what i'm trying to say, my english is not the best.
  • Who's Online   0 Members, 0 Anonymous, 1356 Guests (See full list)
