Triticum Agricolam Posted June 17, 2016 Report Posted June 17, 2016 Well I originally wanted to run 2 12 SAs. My max dimensions are 34l x 16h x 18d. With considering port area, bracing, and the box tuned to 34 hertz how much cubic feet net will each sub have after. I was looking to give them 2 cubes net but that won't fit. I'm guessing with my measurements the subs will see 1.6-1.75 cubes net. Could anyone answer this for me. Otherwise I'll just get a custom box for 2 SA 10s in 2.5 cubes net tuned to 34 hertz On that amount of space two 10's are probably going to be your best bet. Its just a little bit too small for a pair of 12"s. What about running to sundown x 10s off a sundown 1500 or 2000. I know there underpowered but is it worth it or just go with the sa 1500 watts will be fine to a pair of SA-10s, 2000 watts will probably be no issue either, you will just have to be more careful. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
Daddy_ Posted June 17, 2016 Author Report Posted June 17, 2016 Well I originally wanted to run 2 12 SAs. My max dimensions are 34l x 16h x 18d. With considering port area, bracing, and the box tuned to 34 hertz how much cubic feet net will each sub have after. I was looking to give them 2 cubes net but that won't fit. I'm guessing with my measurements the subs will see 1.6-1.75 cubes net. Could anyone answer this for me. Otherwise I'll just get a custom box for 2 SA 10s in 2.5 cubes net tuned to 34 hertzOn that amount of space two 10's are probably going to be your best bet. Its just a little bit too small for a pair of 12"s. What about running to sundown x 10s off a sundown 1500 or 2000. I know there underpowered but is it worth it or just go with the sa1500 watts will be fine to a pair of SA-10s, 2000 watts will probably be no issue either, you will just have to be more careful. Do you know how much net space per woofer I'll have? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200
Triticum Agricolam Posted June 17, 2016 Report Posted June 17, 2016 Based on the dimensions you gave you probably should be able to get 1.25 cu ft per sub. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
