kickass audio Posted June 28, 2016 Report Share Posted June 28, 2016 Hey man, I was looking around and saw that you are a really big help for enclosure building for other members. I had my previous enclosure for my SMD 18 designed by RAM designs but he isn't able to make any designs now as he is really busy. Anyway, I wanted to see if you could help me with a design for a 12" DC audio level 3 sub that will be running on around 1200-1400w rms of power (yes I know it is a ton of power going to it but I am using a DD1 and a CC1 for my setup and have a vu-din to monitor the output going to the sub.) For my enclosure I am looking to tune around 30-35Hz and the max dimensions I am looking to stay within are 16" for width, 16" for height and 16" for depth. If needed I can adjust the sizes of them as my old enclosure was a lot bigger but i'd prefer a smaller enclosure. I am aiming to have as small of an enclosure as possible so it can be light enough that I can remove the enclosure from my truck when needed for cargo area. I will pay you through paypal for your idea on it if you'd like since it is your time to help me with the enclosure. Thanks in advance!! edit: I forgot to add, if you can I also wouldn't mind running an aero port setup on my enclosure as opposed to a slotted port. Any bit of weight savings I would be willing to take but I am going to run 3/4" birch for the wood. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress Link to comment Share on other sites More sharing options...
