Subs cut out randomly
since u recently messed with the ground that is your problem.
maybe not tightened enough see if you can move it with your body weight
give your terminal a good tuggy
Ding ding ding you are the winner, that was the problem I cleaned the corrosion and wrenched down the terminal real tight and Boom....BOOM BOOM BOOM, no more gaps in between booms..lol. Thanks, I'm a idiot for not realizing that in the first place.
bolt holding your trunk latch is a horrible spot. change to the floor pan and that will be tons better. use your own screws as well.
gotta agree trunk latch is a bad spot i would say strut tower or floor pan would be best...unless you wanna break out the the drill and ground it to the subframe, unibody, or chassis frame
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
glad you got it figured out but honestly hope your still not using the trunk latch bolt. go to the floor pan of the vehicle and clean an area to shiny metal and use your own screws and a star washer at a minimum or you will be having issues in the future again.
Ill get that done for sure.
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
