Single z v3 15" enclosure help
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Same external dimensions doesn't mean it's the same spec, the longer 30Hz port likely takes more internal airspace, as posted above you will gain 1+ dB over the 3 net version at tuning, no other side effects.
  • Who's Online   0 Members, 0 Anonymous, 1658 Guests (See full list)
