Single z v3 15" enclosure help
So is it 22" deep or 16.5" deep? You are double deepin'.
Builds:
So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3 3/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Same external dimensions doesn't mean it's the same spec, the longer 30Hz port likely takes more internal airspace, as posted above you will gain 1+ dB over the 3 net version at tuning, no other side effects.
I just measured the port and I think it is tuned way too high. The port is 4 1/2" wide and 15" tall and 22" long overall. Would I be able to add length to the port to get it down to 30hz?
  • Who's Online   0 Members, 0 Anonymous, 3569 Guests (See full list)
