JSavell Posted August 9, 2016 Report Posted August 9, 2016 picked up two tantric hdd 18 going to run in them in a c pillar wall in my explorer dont have any specs on them would this work will add more bracing with 2x4 outside the box .
JSavell Posted August 10, 2016 Author Report Posted August 10, 2016 does this look good ?what would you change? .
Triticum Agricolam Posted August 10, 2016 Report Posted August 10, 2016 Port aspect ratio is higher than I like to see. Other than that its hard to comment without knowing more about the system. How much power are you going to be running? What are your goals for the system? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ToNasty Posted August 10, 2016 Report Posted August 10, 2016 Looks fine to me. 6 cubes. 100 inches of port per. But what's the power ? ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
JSavell Posted August 11, 2016 Author Report Posted August 11, 2016 id like to be able to hairtrick each sub will be on a audiopipe apcl 3000.1plan on a gp 300 amp alt and nsb 480 .
JSavell Posted August 11, 2016 Author Report Posted August 11, 2016 rebaffled a garbage box i got for 4 15" and metered a 48.7 on the dash at 43 hz on one audiopipe 3000.1 with stock alt and 2 extra batteriesthese are the box specs 11.25 cf3 tuned to 28hz with 9.6 port area per foot also subs were bouncing because it broke the construction screws but it was just for a day to hear them explorer is empty now and buying deadener tomorrow .
