Jessica Posted August 17, 2016 Report Share Posted August 17, 2016 So which way should I wire the subs, to 2 separate channels or 1 channel Its the same Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Vice03 Posted August 17, 2016 Report Share Posted August 17, 2016 So which way should I wire the subs, to 2 separate channels or 1 channel Whatever floats your boat - you can wire at 1 ohm both ways. Using both terminals uses more speaker wire. Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 17, 2016 Report Share Posted August 17, 2016 So which way should I wire the subs, to 2 separate channels or 1 channel Whatever floats your boat - you can wire at 1 ohm both ways. Using both terminals uses more speaker wire. I prefer using more wire. Both out outs on each coil. Just me. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Jessica Posted August 17, 2016 Report Share Posted August 17, 2016 So which way should I wire the subs, to 2 separate channels or 1 channel Whatever floats your boat - you can wire at 1 ohm both ways. Using both terminals uses more speaker wire. I prefer using more wire. Both out outs on each coil. Just me. what do you know? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
welderblake21 Posted August 17, 2016 Author Report Share Posted August 17, 2016 OK glad to hear because I was wanting to run one channel Link to comment Share on other sites More sharing options...
Jessica Posted August 17, 2016 Report Share Posted August 17, 2016 OK glad to hear because I was wanting to run one channel you really need to read more Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 17, 2016 Report Share Posted August 17, 2016 OK glad to hear because I was wanting to run one channel For the love of God SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted August 17, 2016 Report Share Posted August 17, 2016 You have no choice but to run one channel. Its all you have. You don't have two channels to run. Just four terminals on one channel. If you take the cover off the back of the amp, you will see how they are connected inside. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
welderblake21 Posted August 17, 2016 Author Report Share Posted August 17, 2016 Yea I understood that it's a 1 channel that's just got 4 inputs but I meant I was only wanting to run 2 of the 4 inputs. Link to comment Share on other sites More sharing options...
Kyblack76 Posted August 17, 2016 Report Share Posted August 17, 2016 Yea I understood that it's a 1 channel that's just got 4 inputs but I meant I was only wanting to run 2 of the 4 inputs.Inputs? A stereo mono board!?Edit. - again. For the love of God SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
