osten45 Posted September 5, 2016 Report Share Posted September 5, 2016 My car is a BMW 1995 525i and it has 4 mid bass woofer, 2.5 inch mids, and tweeters, they are all factory speakers. They are too loud when i turn my kenwood kdc-mp342u deck up so i could get my subwoofer loud. I went to the factory amp to try and turn down the gains but there wasnt anything on there. So would it be easier to put the mids and highs on the head unit and the mid bass on my sub amp and turn the gains down? My sub amp is a 5 channel mtx 5400x. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 5, 2016 Report Share Posted September 5, 2016 Or turn the gain up on the sub. What kind of sub do you have? You probably need a bigger sub with a bigger amp. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
3vil Posted September 5, 2016 Report Share Posted September 5, 2016 Turn down the mids and highs until they blend properly with your sub stage. Link to comment Share on other sites More sharing options...
ShadeTreeMechanic Posted September 6, 2016 Report Share Posted September 6, 2016 They probably blend properly now. lol 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon) Link to comment Share on other sites More sharing options...
