alibaba Posted September 6, 2016 Report Share Posted September 6, 2016 I recently bought the RE usx65kv amp and read up that it has the MLT(multi link technology) allows master/slave mode to have multiple amplifiers powering one speaker, as far as i can tell my amp doesnt have the switch for master/slave but it says its MLT capable can someone shed some light on this cuz im confused thank u. 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 6, 2016 Report Share Posted September 6, 2016 It doesn't look like there is a switch, just an input/output for it. RCA inputs from your headunit into amp #1, then next to those inputs in the in/out for the MLT. A single RCA runs from the MLT out on amp #1 to the MLT in on amp #2. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
alibaba Posted September 6, 2016 Author Report Share Posted September 6, 2016 so can i safely run 2 amps on 1 sub as long as both amplifiers have the MLT feature? 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
alibaba Posted September 6, 2016 Author Report Share Posted September 6, 2016 ive got the usx65kv and the taramps hd2500 but i dont think the taramps has that feature i wish it did 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 6, 2016 Report Share Posted September 6, 2016 Now that I am not sure about. I think so, but I don't want to say yes and be wrong. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
alibaba Posted September 6, 2016 Author Report Share Posted September 6, 2016 ive never done it like that before so im not sure either, tried looking on google but there seems to be no info on it wat so ever, n i def dont want to blow a channel trying it before i kno 110%, if any1 has any eperience with the MLT feature please share. thanks 06 Envoy 250a ALT 2x 2400 kinetiks USX65KV1 w/ parallel bridged mosfets 2200rms @ 1ohm @13v powering 1 Orion hcca122 Taramp HD2500 for mid range 4xPioneer 6x9's 2x 1" Pioneer tweets Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 7, 2016 Report Share Posted September 7, 2016 I'm pretty sure the sub will be what messes up, not the amps. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
islandpride684 Posted September 7, 2016 Report Share Posted September 7, 2016 so can i safely run 2 amps on 1 sub as long as both amplifiers have the MLT feature? As long as both amps are the same with the MLT feature...minimum load is 2 ohms, both pos from master amp connects to pos of the sub and pos from slave amp connects to the neg side of the sub, both neg terminals on amps will not be used... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
MrSkippyJ Posted September 7, 2016 Report Share Posted September 7, 2016 It's not strapable, it's a master/slave style. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
islandpride684 Posted September 7, 2016 Report Share Posted September 7, 2016 It's not strapable, it's a master/slave style. That's what strapping is...same thing for this amp just that it doesn't have a switch but the MLT rca in and out which is the switch...in for slave, out for master....both amps has to be identical... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410 Link to comment Share on other sites More sharing options...
