Crossovers to close?
r.sok
-stinger 6000 series rca
-Memphis 12 gauge wire
-Memphis 4 channel amp
-Boston acoustics 6.5lf pro series components
I notice when the stereo is all the way down or really low volume I get some type of slight feedback from my tweeters. It males a slight Whirl sound. no hum/whine & it doesn't increase with volume. It only happens when the tweeter is on the "0" setting. -2/-4 it doesn't do it at all. Any clue to what it may be?
Crossovers are mounted inside the door cavity on top of deadner & power/Rca are on different sides of the car. I've noticed it only happening with these components & my hybrid audio components. On cheap sets it doesn't do it at all
Does it go away if you turn the amp gain all the way down?
Pioneer 80PRS
Yeah with the gain all the way down the noise isn't there. But if I put my gain all the way down then my speakers don't play that loud. Max volume is 30 & my hu clips around 25
What the numbers are aren't relevant for anything more than a reference point for how you set stuff. If you have to crank the gains way up your HU isn't putting out a decent voltage.
The high quality components really do let you hear more lol. Did you change anything else when you changed components?
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
You might need a pre amp to drive the line so you can keep the gain down. Some EQs have a pre amp built in. I did this and it made a big difference.
Pioneer 80PRS
This h/u puts out really low voltage. I'm guessing somewhere around 1-2 volts.... Yes that low. Changing the head unit isn't an option for me. Kind of hard for me to give up the features it has to offer. Android based, Internet browsing, app downloads, essentially it's a tablet. Is there something you guys would recommend to boost my rca voltage without compromising sound quality?
The only thing I changed when installing these components are the connector ends of my wire to fit the midrange.
The speakers do sound really good with perfect balance "eq set flat" but the real low volumes during morning drives kind of drives me crazy.
All the loud features are set to "off" & eq cutting doesn't make a difference
You need a pre amp.
Pioneer 80PRS
  • Who's Online   0 Members, 0 Anonymous, 1962 Guests (See full list)
