Kauaian Posted September 17, 2016 Author Report Posted September 17, 2016 Best i could do using your dimensions was 3.8 net with 64" of port area tuned to 36. i don't have WinISD to see if that will work with your subs or not but the port area seems pretty low to me. To get a reasonable amount of port area and tuning you need more space. what is the closest we can get? I kind of just want to try and make it work :\
ChevyBoy95 Posted September 17, 2016 Report Posted September 17, 2016 3.87 ft^3 final 34Hz tuning w/ 49.5 sqin of port Total Outer Dim. -> 35" W x 18" H x 17.5" D Port Size -> 3" W x 16.5" H Port Piece 1 -> 12" long Port Piece 2 -> 6.25" long Total Usable Port Lengh -> 23.75" edit: that is probably what I would build, and if it doesnt do something I want it too well, i would rebuild it. Should only take 1 sheet of wood to make and an afternoon. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Kauaian Posted September 17, 2016 Author Report Posted September 17, 2016 3.87 ft^3 final 34Hz tuning w/ 49.5 sqin of port Total Outer Dim. -> 35" W x 18" H x 17.5" D Port Size -> 3" W x 16.5" H Port Piece 1 -> 12" long Port Piece 2 -> 6.25" long Total Usable Port Lengh -> 23.75" edit: that is probably what I would build, and if it doesnt do something I want it too well, i would rebuild it. Should only take 1 sheet of wood to make and an afternoon. Thank you so much! Sorry for the noob question but what do I do for that brace?
ChevyBoy95 Posted September 17, 2016 Report Posted September 17, 2016 3.87 ft^3 final 34Hz tuning w/ 49.5 sqin of port Total Outer Dim. -> 35" W x 18" H x 17.5" D Port Size -> 3" W x 16.5" H Port Piece 1 -> 12" long Port Piece 2 -> 6.25" long Total Usable Port Lengh -> 23.75" edit: that is probably what I would build, and if it doesnt do something I want it too well, i would rebuild it. Should only take 1 sheet of wood to make and an afternoon. Thank you so much! Sorry for the noob question but what do I do for that brace? I have always used 2x4, and in this case, it is 16" long. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
