Kauaian Posted September 15, 2016 Report Posted September 15, 2016 So I've been trying to come up with a slotted box design for my two skar vvx12v3's. I'm not sure if I'm overthinking my first box but it's very intimidating and I really could use some help coming up with a design. I have two skar vvx12v3s and my trunk space is 35x17.5x18 and I already have a sheet of 3/4 inch MDF. I'll be using a SQ 1200 for now in the trunk of a 2002 Honda Accord
sTp Posted September 15, 2016 Report Posted September 15, 2016 So just a couple of questions i guess you want sub rear port rear and from your dimensions the width is 35 and out of the other two dimensions ( 17.5 and 18 ) which one is height and which one is depth
ChevyBoy95 Posted September 15, 2016 Report Posted September 15, 2016 So I've been trying to come up with a slotted box design for my two skar vvx12v3's. I'm not sure if I'm overthinking my first box but it's very intimidating and I really could use some help coming up with a design. I have two skar vvx12v3s and my trunk space is 35x17.5x18 and I already have a sheet of 3/4 inch MDF. I'll be using a SQ 1200 for now in the trunk of a 2002 Honda Accord if the box is made to these dimensions, will it slide in through the trunk opening. That is an important thing to look at too. Just because it will fit IN the trunk, doesnt mean you can get it in the trunk is all. Make 110% sure. So just a couple of questions i guess you want sub rear port rear and from your dimensions the width is 35 and out of the other two dimensions ( 17.5 and 18 ) which one is height and which one is depth x2 Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
sTp Posted September 15, 2016 Report Posted September 15, 2016 +1 on what chevyboy wrote its best to make a template from cardboard to make sure you can fit the box in the trunk.
DLHgn Posted September 15, 2016 Report Posted September 15, 2016 So I've been trying to come up with a slotted box design for my two skar vvx12v3's. I'm not sure if I'm overthinking my first box but it's very intimidating and I really could use some help coming up with a design. I have two skar vvx12v3s and my trunk space is 35x17.5x18 and I already have a sheet of 3/4 inch MDF. I'll be using a SQ 1200 for now in the trunk of a 2002 Honda Accord We've all been there. Hopefully it'll all come out as planned and you'll be satisfied. Worse case scenario, you'll have to redesign/remake your box. Luckily the wood is usually the cheaper part of the build.
Kauaian Posted September 16, 2016 Author Report Posted September 16, 2016 So just a couple of questions i guess you want sub rear port rear and from your dimensions the width is 35 and out of the other two dimensions ( 17.5 and 18 ) which one is height and which one is depth Thanks for the reply! it's 17.5 deep and 18.5 tall and yes rear facing for both if that's recommended
Kauaian Posted September 16, 2016 Author Report Posted September 16, 2016 So I've been trying to come up with a slotted box design for my two skar vvx12v3's. I'm not sure if I'm overthinking my first box but it's very intimidating and I really could use some help coming up with a design. I have two skar vvx12v3s and my trunk space is 35x17.5x18 and I already have a sheet of 3/4 inch MDF. I'll be using a SQ 1200 for now in the trunk of a 2002 Honda Accord if the box is made to these dimensions, will it slide in through the trunk opening. That is an important thing to look at too. Just because it will fit IN the trunk, doesnt mean you can get it in the trunk is all. Make 110% sure. I'm not too sure but a guy on YouTube had a 15 with a box of those specs. My back seats do fold down so that's always an option
sTp Posted September 16, 2016 Report Posted September 16, 2016 Right i will have a look on Torres tonight for you as i have the dimensions and check your space out as you might not have enough room but will check that when i get home from work.
ckeeler11 Posted September 16, 2016 Report Posted September 16, 2016 Best i could do using your dimensions was 3.8 net with 64" of port area tuned to 36. i don't have WinISD to see if that will work with your subs or not but the port area seems pretty low to me. To get a reasonable amount of port area and tuning you need more space.
sTp Posted September 16, 2016 Report Posted September 16, 2016 Sealed Volume : 1.75 ft^3 Ported Volume : 2.25 ft^3 Port Area : 24 sq.in. Port Length : 21" Tuning Frequency : 33 Hz Mounting Depth : 7.25" Cut-Out Diameter : 11.25" Magnet Diameter : 7.13" Subwoofer Displacement : 0.17 ft^3 That's the spec that Skar recommend for 1 sub so wouldn't 64'' of port area be OK as you only need 48'' of port area but they also recommend 4.50 cuft for both subs box so like ckeeler11 says you need more space really to make it work.
