Right now i have 2 skar audio Lp 1000.1dv2 amps and i wanna run 4 amps. i know i can have one amp as the master amp and the other 3 amps as the slave amps. i was wandering how i can hook up 4 skar audio vvx12v3d4 to the amps?
Head unit Pioneer deh-80prs
Sub Amp
Highs Amp Skar audio Lp 60.4
Tweeters and Highs 2 Skar audio fsx 6.5 and 2 spx-t
Subs
Batteries?
alt?
  • 2 months later...
Being that you have 4) VVX-12v3 D4 if you did 2 on 1 amp it would be @ 1 or 4 ohm i would not suggest that. Maybe put 1 amp on 1 sub i would recommend this.
-Shane
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
If it was me , I would break in the subwoofers and burn in the amp first @ 2 ohm load . That amp supposedly gives 700 watts into a 2 ohm load and those subs are rated @ 600 watts. I wouldn't turn the volume up past half-way for the first month or about 10 hours of playing music. If you're planning on running one subwoofer per amp , then each sub would play @ 2 ohms (recommended) or an 8 ohm load . Thats what I would do if you wanted to run all the equipment you had.
  • Who's Online   0 Members, 0 Anonymous, 1837 Guests (See full list)
