I got 2 ab 8"s that are dual coil 4ohm. I want to get a 2ohm load to my amp but dont know how to do it. I seen a diagram but im not sure if its the right one.
http://www.sonicelectronix.com/lp/pla-8-car-subwoofers/vfl8d4?utm_source=google&utm_medium=cpc&utm_campaign=PLA&affiliate=googpla&scid=scplp7970863&sc_intid=90855&gclid=Cj0KEQjwsO6-BRDRy8bsxfiV2bkBEiQAF8EzKGhTt2zOpwVDriZJjhpYNvIKBrir05ZbsI8Pi8cFCRQaAj2Q8P8HAQ
http://www.sonicelectronix.com/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_2ch.jpg
I hooked up a ohm reader and it read 2ohm on each sub using the diagram above. My amp is 2ohm stable so it should work?
If you are hooking it up to a 2 channel amplifier that is 2OHM stable, then yeah... It should work. What amp are you using?
last time I checked, two dual 4ohm voice coil subs can only be wired to 1ohm, 4ohm, and 16 ohm. not 2ohm.
It's a 2 channel amp.
ahh, guess i should have checked the links. my bad OP
