Aero port help
Jhensley209
Assuming you are going to be running somewhere around rated power, two 6" ports would be the minimum. They may be difficult to fit in the box though and get the tuning you want.
Builds:
Port length would be way too long for 2 6" aeros
Probably should do a slot port then.
How much power are you going to run?
Builds:
how big of ports for a box 32 x17x24 sealed in the center with 2 15 inch ppi black ice 550 rms and were to place them? with 2 800 watt legacy amps going to them
You should start your own thread.
Builds:
I built a slot port box for them already just wanted to try using aero ports. I have them on a ct sounds at1400 right now until i get my ct4000 back from being repaired
Have you started construction on the aero port box yet, or are you still in the planning stage?
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1204 Guests (See full list)
