Can someone please check this design?
1 SAZ-3500
2 12" Eminent Audio 2K D4's (1 Ohm)
1 Kinetik HC3800, And a datasafe (Same size but forgot specs)
Sony radio with 5V pre-outs (Forgot model)
I know the box is a little small, but it's about max dimensions for my malibu. Just want to make sure port looks good before I go building.
Without the specs for your subs I can only make an educated guess, but I think you are quite a bit short on port area. I realize space is at a premium so compromises will need to be made, but if you could fit some more port area some how, it would be good. I'd like to see at least 60 sq in if possible.
Builds:
Name= Emient 12 cast EA2000 motor
Note= 04.29.2011
Model= TSL
Domain= FreeAir
Shape= Round
Profile= Cone
Fmd= 3.0000 KA
Qmd= 1.0000
Flp= 8.0000 KA
Qlp= 2.0000
Znom= 1.0000 Ohm
Revc= 2.0000 Ohm
Sd= 55.0000E-3 M²
Mmd= 222.4670 g
Pmax= 2.5000E3 W
Rtvc= 1.0000 °C/W
Xgap= 20.0000 mm
Xcoil= 60.0000 mm
Xmax= 20.0000 mm
Krm= 9.9300 mOhm
Erm= 884.0000E-3
Kxm= 95.3000 mH
Exm= 520.0000E-3
Rms= 7.0417 N·S/M
Mms= 229.8800 g
Cms= 67.6700 uM/N
Vas= 29.2376 Ltr
Fo= 40.3526 Hz
Qms= 8.2770
Qes= 0.6112
Qts= 0.5692
BL= 13.8100 T·M
Levc= 1.4320E-3 H
SPLo= 86.8090 dB
No= 301.3000E-3 %
* End
I was messing around with a 4" port last night but after getting the tuning where I want I think I was around 2.5-2.75 ft net. Wanted to do a aero originally but everyone was suggesting a 8" aero. Would be hard to tune to anything less than like 46 hz with the space I have
you would probably better off doing 1 12". It would be alot more efficient since you would be able to give it the required space and port area.
Like ckeeler11 said, you are probably better off with the single 12", you just don't have the room to do two 12"s properly. If you can find a way to get more space that would change things. Another option would be to run two 10"s.
Builds:
Damn okay... I had originally bought 3 of these. Got one re-coned as a D2 first and the other two as D4's a few months later. Didn't realize I would run into this much of a issue with the space in this car
did not look at specs but you could run sealed, but then a single 12 in a proper ported box will most likely be louder than 2 12's sealed. unless you really up the power.
  • Who's Online   0 Members, 0 Anonymous, 15549 Guests (See full list)
