bamby Posted November 1, 2016 Report Posted November 1, 2016 Hi I'm planing on adding a sub woofer for my car. Already have SKY High Car Audio 1/0 OFC power wire and terminals to install big 3 and use it for power wires. From what i measure i have the option of entering a box of 3.5^3 Ft. What power and Sub or Subs do you guys recommend for this space. I don't play lows, frequency will be between 30-60. Budget around 1.5k on amp and sub. Thanks
Triticum Agricolam Posted November 1, 2016 Report Posted November 1, 2016 What exactly are the dimensions you wave to work with? What kind of car is it? "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
ShadeTreeMechanic Posted November 1, 2016 Report Posted November 1, 2016 The port will take up some room too. Off the top of my head it sounds like a single 15 or possibly a pair of 12s. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
