Xdq_21X Posted November 6, 2016 Report Posted November 6, 2016 I want to add a second battery in the trunk, my question is do my 2 batteries have to match each other? The battery under the hood is stock but I want to add a bigger one in the trunk...is that going to be okay? Or what??
reedal Posted November 6, 2016 Report Posted November 6, 2016 as long as they have the same resting voltage, it is fine. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Wishuponasub Posted November 6, 2016 Report Posted November 6, 2016 Yes that's perfectly fine. You just don't want to mix types of batteries. For example If you have a regular lead acid battery up front you don't want to put an AGM batt in the back or vice versa. Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
Xdq_21X Posted November 6, 2016 Author Report Posted November 6, 2016 Yes that's perfectly fine. You just don't want to mix types of batteries. For example If you have a regular lead acid battery up front you don't want to put an AGM batt in the back or vice versa.Okay thank you?
Tomas Vega Posted November 18, 2016 Report Posted November 18, 2016 Can I ask a question how about if I have 1 Xs power d2400 up front to turn on the vehicle and 2 xp3000 will it damage each other or is that Not a good mix of batteries or should I as a isolator
reedal Posted November 18, 2016 Report Posted November 18, 2016 Can I ask a question how about if I have 1 Xs power d2400 up front to turn on the vehicle and 2 xp3000 will it damage each other or is that Not a good mix of batteries or should I as a isolator Those three batteries will work just fine together. They're all AGM. No need for an isolator SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
SkarredSierra Posted November 18, 2016 Report Posted November 18, 2016 Ive ran with a lead acid up front and an agm in the rear for almost 4 years. No issues. And no isolater.
reedal Posted November 18, 2016 Report Posted November 18, 2016 the only issue that could come from mixing regular lead-acid and AGM is the difference in resting voltage and lifespan. whichever is the weaker of the two upon connection, that one will leach off of the other until they are at equal voltage. which is typically only less than or equal two .2vdc SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
